2 hours ago
This is less of a question and more just some feedback. My plan has US roaming and I purchased and talk/text plan for 15 days. I went down to Minneapolis for a week and on the day I was coming home I lost both roaming data and all talk/text ability. I had to go to place that had wifi to set my route home. When I got to the border and changed to public mobile network. All the data came on and all texts came through. What gives? I have never had an issue like this before
17m ago
With your plan, I think you'll find that you can use talk/text and data whilst in US and Mx. For data usage, you do need to enable Roaming otherwise talk / text work just as they do at home...no need to buy any roaming add-on. Follow suggestions re: manual selection of better network when you run into poor connectivity in US or Mx. In Mx, you can select for the better of AT&T, Telcel and Movistar. No need to spend $$ for nay roaming add-on with your current plan.
23m ago
Thanks for the reply. My plan has states/mexico roaming which allows me to use my data while in the states. I know as once while I was in Vegas, I had bought a data package and it never got use and gone after the expire date occur. On that same trip, I had no voice/ text ability. After the trip I learnt that data is available while in the states but voice/text only available in Canada to the states. Unless public mobile has changed, that’s the way it works (I think)
33m ago
Thanks for the reply. This is something I will have to remember next time I’m down in the states. Interesting that it stopped working on the day I was heading (driving) back to Winnipeg.
an hour ago
can you please clarify....you have a Canada and US plan but you also bought a 15 Day US talk/text add-on for $15...is that correct ? If so, you didn't need to buy that add-on as you're able to us your talk/text and data in US just as you would at home. You just need to enable roaming in settings to have access to data whilst in US.
As others have suggested, you might hafta manually select the better of AT&T, T-Mobile and Verizon...whichever works best.
2 hours ago
@Stig58 , I think if auto network connection does not work, you need to manually select a network partner to connect to. I have a CAN-US-MX plan. In October, I travelled to Minneapolis from Winnipeg and on the way back, I also lost phone functionality somewhere along the way to Fargo. I was able to manually connect to T-Mobile and re-establish phone functionality. At the border, I switched back to auto network connectivity. Maybe there is some sort of network issue in the local region that requires manual network connection.
2 hours ago
If your US roaming package expired before the full 15-day period, please don't hesitate to reach out to Public Mobile to explore a resolution. I understand you've already returned to Canada, but they appreciate the feedback — it helps them improve the experience for all customers.
