05-19-2022
12:22 AM
05-19-2022
10:11 AM
Dunkman
Agent registered and activated my number (at the shop) with a wrong email address and when I tried to create my self-serve account with the correct email, it wouldn't let me and it was then I realized that the agent made a mistake in the email address when registering and activating my number at the shop.
I am now forced to use a wrong email address to create my self-serve account and community profile. I want to change the email address associated with my number to the correct one, how do I do it?
Thanks..
05-19-2022 01:14 PM
That's reason why YOU SHOULD the activation and EVERYTHING by yourself
05-19-2022 06:18 AM
This has happened many times, but the good news is the affected parties have a pretty good track record of getting it resolved painlessly👍
05-19-2022 12:33 AM
Create your self serve account and profile. Record all of the pertinent info to put in a safe place. Then contact customer support to change the self serve account email. Then if you used the incorrect email to create your community account change it to the correct one in your profile. Make sure you verify it afterwards.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-19-2022 12:24 AM
@Covenant Should be an easy fix by PM Support. Just open a ticket by direct message:
