Hello please help asap it's been 24 hours
04-17-2024 08:44 PM
I got resolved for app store issue from this community, now only thing is on my dad's iPhone xr this e sim is not activated , tried everything
We have a new number, e sim downloaded on his I phone
I paid from my public mobile account, my credit card and my email address linked
But new esim, with new toronto based number , with 50 gb data for 34 dollars a month is for my dads I phone xr
It says still activating then says cannot activate after few minutes.
Service
04-17-2024 08:50 PM
@Nkau007 - Did he port in his number from another provider? Please check if the old providers SIM still works.
Also try clicking on "Didn't get the code?" and send it as an email. If it is not there just "Resend Code" please try 4 times of incorrectly entering the 6 digit code - some people say that they've got it to popup.
04-17-2024 08:47 PM
It says a 6 digit code will be sent to new public mobile cell number but my dad never received the text to fully activate. How can we achieve that
04-17-2024 08:46 PM - edited 04-17-2024 08:47 PM
@Nkau007 - Please look at the activation email, it will look like this:
Also check in Settings > Cellular for the eSIM, if it is installed but not enabled - enable it. If it is not there at all - please scan QR code.
Then scan the QR code for eSIM activation. If he already deleted it... you will need a new one from CS_Agent (The second eSIM cost is free also.)
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
