02-07-2022
03:49 PM
02-08-2022
12:04 AM
Dunkman
I tried to purchase an add on. Paid for two add ons nothing is working. What’s the problem
02-07-2022 07:15 PM
If you tried to purchase 2 of the same US Roaming add-on, you'll run into problems.
These can only be purchased once per 10-day period. After the 1st expires, after about 24 hours you can add the same Roaming add-on again for another 10-days.
If you weren't referring to the US Roaming add-on, then the prior posters have probably assisted you sufficiently.
02-07-2022 04:50 PM
Can you see the balance in your account?
Can you see these add-ons on your plan?
If you can see the balance then they are still to be bought.
If you can see them in your plan, reboot the device.
02-07-2022 04:35 PM
02-07-2022 03:52 PM
Purchasing an add-on after logging in into your PM account is a two-step process. You need to load funds first and then purchase add on.
- Add funds to your PM account: Any funds to buy add-ons come from your balance, so manually add funds to your available balance first.
- Buy Add-On: You will actually buy the add-on after you add funds to your account or else you won't have funds to actually buy the add-on. Funds to buy add-on come from Your account (after adding funds in step #1) and not directly from your credit card.
