04-01-2024 11:28 AM - last edited on 04-01-2024 05:22 PM by computergeek541
Hi! need to activate my SIM card
i paid for my services already since last week and i would like to have my services turned on plss
04-01-2024 11:51 AM
You won’t be charged until the SIM is activated on the PM app.
04-01-2024 11:30 AM
@Zabelle Have you down loaded the app yet . You need. The app to activate the sim
04-01-2024 11:30 AM
@Zabelle , are you able to continue with the activation process now that you have received your SIM card? If the account was created previously, you should be able to access it to continue the process. Make sure to use the app.
04-01-2024 11:30 AM
hi @Zabelle
did you use the Public Mobile app? if you are just using browser, it wasn't done, you need to use Public Mobile app to finish it, please download and login and complete the rest of the steps
if you used the app and got to the end, may I know if you have physical or esim?
and you can also ask support agent for help. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
