11-21-2024 12:58 PM
My SIM card does not work, how can I get a new sim card linked to my phone number?
11-21-2024 01:19 PM
@ae489 Another option is if your phone eSIM compatible you can just log into the app with phone and buy eSIM right away and save yourself a trip to the store also fastest way to get up and running again
Notice “purchase SIM card “ tap it and choose eSIM
11-21-2024 01:05 PM
@ae489 wrote:Thank you. I need to buy a new SIM card than.
See if there's a Mobile Klinik in your area as they usually have the PM sims available. Alternative...source one from Amazon...just don't get one from PM as it might be a long time before you get it due to Posties on strike.
11-21-2024 01:03 PM
11-21-2024 01:03 PM - edited 11-21-2024 01:18 PM
you just need a new sim, then log in to your account to Change Sim Number and you're good to go.
added...if you use the PM app, log in to your account / scroll down to Change Your Sim Card...then make the change.
11-21-2024 12:57 PM
hi @ae489
sim card rarely fails, did you try your sim on another phone? or try other active sim cards on your phone to confirm it is not a device problem?
To get new sim card, buy from Telus or Koodo store or via Amazon:
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
11-21-2024 12:56 PM
I need help.
I am new in public mobile and I do have problem with my sim card, how I can get a new sim card?
