Sum unknown number
Lloyd4
Is there an easy way to add my number to sim card in settings. Everything works. Ulephone pro16
Lloyd4
I ported my number from bell following the instructions I PM app
Lloyd4
Ok thanks
@Lloyd4 wrote:
I just did it today at work I'll try that when I get home
@Lloyd4 , if you ported over your phone number and the port is working fine, I think eventually the new number will display properly in the phone settings.  Depending on the phone model, it does seem to take a bit of time for the information to display properly in the SIM status despite phone calls and text working properly on the correct number.
Lloyd4
slusagm
you can make and receive calls no problem?
what happens if you test your sim in another phone?
HI @Lloyd4
Try Reboot phone first, then try Reset All Networks
