Account Login without Code
Tere
Hello,
My mobile got stolen. I have a new mobile now and bought a SIM Card. I need to swop my number to this card now for this I need to access my account. The problem is that when I login with my name + password its sends a Code to my stolen mobile and I cant access my account anymore.
What should I do now?
Thank you, Theresa
@Tere
you tried to have the code to send to email?
If you have already created an EverSafe id, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
If that didn't work, Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support by direct message here:
@Tere  Try tapping resend code a few times . You should get option to send code to email instead . If no luck . Pleas submit ticket with support to help
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
hairbag1
@Tere
after several unsuccessful tries to send code to you by SMS, it'll offer your code by email.
