Account Disabled and No Service
ramshaansari
Hi there,
Two days ago, my service came to complete stop and I have been unable to login to my online account. Would love to get some help on this !
30 REPLIES 30
No, what? Did you try devicecheck.ca? Did you recently have credit card problems? Did you contact the support people yet?
Buckslikeyonnis
Is there a way for me to get my number bck up and running
Buckslikeyonnis
No
Ali03
@ramshaansari wrote:
Will go ahead and do this, thank you !
When reply not a bad idea to quote what you reply to otherwise confusing...
Did you try devicecheck.ca? Did you recently deal with problem transactions on your credit card?
Buckslikeyonnis
When I dial 611 it doesn’t play the out the options to top up my number the call fails
Spudster
@Buckslikeyonnis
Looks like you posted a question within another thread.
Apply the voucher number using self serve or by dialling * 611.
Some vouchers take some time to become usable - make sure you using the correct set of digits on the voucher.
If it doesn't work using one method, use the other.
Buckslikeyonnis
How do I fix this I recently bought a voucher to top up my number and I don’t want to accept that it’s going to waste
Logging in could be an unrelated coincidence. Maybe ramshaansari could also try 1-855-4pu-blic and enter their number and see what it has to say. Or try their sim in another phone.
but even a blacklisted device,  My Account should be accessible.    Hope it is not a SIM Fraud case
And the devicecheck mentioned earlier?
ramshaansari
ramshaansari
No problems with payment and no new card, it just stopped working three days ago. I had no problems before hand.
ramshaansari
Was working three days ago, has stopped since then.
JL9
a private message to CS_Agent may be the easiest way, especially if you can't even determine status of your account with 611 and your plan completely stopped in middle of an active 30 day period.
dust2dust
Can you answer if you had recently dealt with any credit card charge problems? Maybe got a new card because of it?
Spudster
@ramshaansari
Send a private message to the Customer Support Agent by clicking here
You’ll need to be logged into your Community account for the link to work.
Renewal is in May. I am on auto-pay. Called 611, get a message saying “Sorry, we can’t process request. Also tried resetting password, that did not work either. Rebooted and all, still no luck 😕
While you are waiting for further advises, initiate talk with the agent not to waste time:
- Use the ticketing system for a faster response time (preferred method as Ticket is assigned and easy to follow up with CSA). Click Chatbot - Ticket and type ticket, then click on Contact Us, then click on issue you inquire about. Link for creating ticket will be presented. It ticketing does not work very fist time do the below.
- Send a private message to the CSA - agent by clicking Here
Hi @ramshaansari, and your service was working yesterday?
ramshaansari
How would I be able to contact an agent. I’ve never done so before.
Thanks!
@ramshaansari
 What does dialing 611 say?
Spudster
@ramshaansari
Check this to be sure your device has not been blacklisted:
https://www.devicecheck.ca/check-status-device-canada/
ramshaansari
Spudster
@ramshaansari
Before 2 days ago did you have FULL services and were you able to log into your account online?
Was your last top up up more than 90 days ago?  After 90 days from the date of last service, one's service and login to self-serve becomes permanently disabled.
I’m on a $50 plan and the renewal day hasn’t passed yet.
Can you try your SIM in another phone?
Does your phone says it is connected to PM?
Did you try standard remedies: reboot, re-seat SIM, reset network settings...
ramshaansari
JK8
@ramshaansari
A few more details? When was your renewal date? Are you on auto pay? Can you call 611 from phone to get Account Status? Have you tried Forgot your password link for self service?
Have you tried rebooting, resetting network settings or reinstalling SIM card?
dust2dust
1. Are you on the $10 plan?
2. Have you recently dealt with any problem credit card charges.
Meow
What do you hear when you call 611?
Did you you do any chargeback against PM on your credit card?
What error do you get when trying to log in?
If you cannot log in to your account contact agent for assistance.
Hi @ramshaansari if you have no services and cannot login, that is a concern  Open ticket with PM CS Agent immediately:
Click on the Bubble or directly at : https://publicmobile.ca/chatbot.   Follow this to get to ticket open screen quicker:
first type: Contact CS Agent
Then Click "Contact Us"
and Click "Other"
finally Click "Click here to submit a ticket"
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
