12-07-2023
01:35 PM
12-07-2023
04:21 PM
Dunkman
Just wanting to ask when does the community reward points being calculated and added to the account?
Anyone know how do they evaluate?
Thanks
12-07-2023 02:04 PM
@MikeZha1 It’s a secret formula that only PM knows but what I can share is that
By participating , reading and helping others with questions . And learning and sharing and good things will happen
ranked chart here
12-07-2023 01:41 PM
HI @MikeZha1
points will be added within 24 hours. Try to use Incognito/private/secret mode to login My Account to avoid browser cache problem
12-07-2023 01:40 PM
The exact formula is unknown to the community members.
Usually a combination of number of posts, number of bravoes and solutions received.
To get the higher rewards like 10-15 points/30 days, you will likely need to spend a couple of hours a day participating. Really not worth your time if you are doing it just for the money. If you want to participate and help others as much as you want or can, then go for it and see how much rewards you will receive.
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
