611 support down and website ? Need support
11-04-2022
10:36 AM
11-05-2022
10:18 AM
Dunkman
Havent been able to call 611 for a couple weeks...
It sends me a text to use the website login than sits there and silence.
Anyone else getting that...
And now with the website down I can't add more data or change my plan to one with more data ....
I'm supposed to work in 1.5 hours and needing to access stuff on data is a requirement ... Starting to panick a bit!
Any solutions ?
My Account
11-04-2022 12:01 PM - edited 11-04-2022 12:05 PM
Ummmmm...no...I thought it was worth a shot. Can you call 611?
Edit:
OK that's weird....so I called it from the phone that can't call 611 like the OP and I got someone's personal number? How does that work? I best edit out that phone number...
11-04-2022 12:00 PM
HI@Amandaboser *611 works for me as well as the 1855 #
I can check my account, I just didn't try to pay or so
11-04-2022 11:58 AM
@darlicious- I know that's the number 611 converts out to but it doesn't work. Did you try it?
11-04-2022 11:45 AM - edited 11-04-2022 12:05 PM
Try calling 1 647 778 XXXX and see if you can access 611 thru that number?
11-04-2022 11:15 AM
Uh oh! Me too! This isnt good. Then your only option is to contact customer support.
Is this issue user specific?
11-04-2022 11:13 AM
@Amandaboser wrote:Just called that number two times on my phone and another on a family members phone who's completely with a different company ...
I just called 1-855 from land line and from my PM phone and it works!
Was able to hear next renewal date, balance, etc.
Let see how autopay will work tomorrow. SO SCARY! 😱
11-04-2022 11:11 AM
Nothing but silence when calling just like the 611 number.
I'm supposed to work in an hour and need data... I went through all mine and either need to add data or change my plan to higher data!
Definitely a little frustrated, but I guess nothing I can do 🤷🏽♀️
11-04-2022 11:11 AM - edited 11-04-2022 11:11 AM
My Account does not work
My Rewards does not work
611 does not work
1-855-478-2542 works
11-04-2022 11:07 AM
No, I will try that.. thank you!
11-04-2022 11:07 AM
I haven't been able to call 611 for 2 weeks ... It just sends me a text and than either hangs up or continues a silence.
No pre recorded options like normal.
11-04-2022 10:53 AM
Have you tried calling 1 855 4PUBLIC and enter your 10 digit phone number. Can you access the 611/IVR system that way to purchase add on data?
11-04-2022 10:42 AM
Nothing seems to be accessible on the PM website this morning...check the Community Forum later for updates.
