12-16-2021 11:19 AM - edited 01-04-2022 04:55 AM
I just ran out of my regular minutes. But I got a holiday "gift" of 500 intl long-distance minutes... so can I use those for my regular local calls ??
12-16-2021 01:53 PM
@computergeek541 wrote:The question had already been answered a few hours ago.
Would it not make more sense to just make a comment. We all know there will be numerous and correct answers. Moving them to oblivion makes no sense. But there are ssome other ones that could be moved especially the over done ones that don't come near to responding to the OP.
12-16-2021 01:50 PM
12-16-2021 01:50 PM
@LeePublic wrote:@computergeek541 I'm confused why you deleted my post......
Mine keep getting moved and this is what I see now...what a pain!!
12-16-2021 01:48 PM
12-16-2021 01:43 PM
12-16-2021 01:06 PM
12-16-2021 12:58 PM - edited 12-16-2021 12:59 PM
@hairbag1 wrote:
@EveB wrote:I just ran out of my regular minutes. But I got a holiday "gift" of 500 intl long-distance minutes... so can I use those for my regular local calls ??
Yes....you can use'em for local as well as some international calls.
edit; another option is to get the $5 / 500 minutes of Canada wide calling add-on. Add-on minutes will be used when your regular plan minutes are used up. Any add-on minutes that are remaining when your regular plan renews, will be saved until you need them next.
I would suggest to follow @hairbag1 suggestion. Your LD freebie has an approximate value of $15. Preserve it for LD calling by purchasing the $5 500 add on. The unused portion rolls over month to month until used up.
12-16-2021 11:49 AM
Yes, you can plus you can call assorted countries.
If you ever plan to call somebody in those countries, maybe better idea will be to invest $5 into 500 Canada minutes and save bonus minutes for overseas.
12-16-2021 11:28 AM - edited 12-16-2021 11:34 AM
Yes, you can make calls across Canada.
12-16-2021 11:20 AM - edited 12-16-2021 11:24 AM
