12-05-2021 08:53 PM - edited 01-04-2022 04:55 AM
How do I make an inquiry into issues with the cell tower closest to my house? I find anywhere near my house the bars are low on my phone, sometimes rendering data unusable. Anywhere else in the city my reception is near perfect.
12-16-2021 02:24 PM
.. If PATH in Downtown Toronto, many antennas set behind the Commercials Ad along the path 🙂
12-16-2021 02:23 PM - edited 12-16-2021 08:16 PM
The cell site equipment is indoors. Typically ceiling-mounted indoor antennas in commercial venues with low power. Sometimes they are hidden behind walls or ceiling tiles, but usually they are visible.
Could look like any of these...
12-16-2021 11:04 AM
What is an indoor site?
12-15-2021 02:28 PM
As previously mentioned by @sheytoon that is an indoor site.
12-15-2021 01:03 PM - edited 12-15-2021 01:11 PM
Not according to the map:
Also yesterday I was in the parking lot of Costco across the street from a Bell tower and I hit -50dbm. So something is wrong with the towers closest to my house.
12-15-2021 12:53 AM
idk 🤣
12-14-2021 09:49 AM
Ok but there is no Telus tower in London. Unfortunately you are at the mercy of Bell.
12-14-2021 09:19 AM
Signal has down the drain since the so called upgrades to towers in October / November.
12-13-2021 08:48 PM
@dmbcanada wrote:I have opened a ticket and gotten it escalated as my data is unusable right across the street from a Telus tower!
@dmbcanada Telus only has indoor sites in London. All outdoor macros are owned and operated by Bell.
@gpixel what do you mean 5G interference is strong?
12-13-2021 05:45 PM
You may not be connecting to the tower across the street if it is not carrying the correct bandz for your service.
12-13-2021 02:19 PM - edited 12-13-2021 02:21 PM
5g interference is strong. LTE signal will be lower because too much radiation is bad for you
12-13-2021 12:44 PM
12-07-2021 08:53 AM
It may also do with the equipment upgrades they are performing on cell towers. London should have been finished by now but maybe azimuth has changed slightly so you don't get as direct of a signal as you were before.
Doesn't explain why I have such a poor signal in the middle of Vancouver?!!
12-07-2021 08:08 AM
So I fiddled around last night and removed my sim card, and changed my network from LTE to 3G a few times and when I changed 3G for a second time my dBm improved from -108 to 98 dBm. Now at work my signal has improved to -79dBm. So I think their is an LTE issue in London.
12-06-2021 01:49 PM
So that's a clue....Ive looked for more info on this issue but haven't found any real answers yet. Try the moto community and report the issue to F1 in your phone. Your family with moto phones should report it as well. I will keep looking and report back on anything else I might find.
12-06-2021 01:11 PM
Everyone is using Moto phones of some sort. Sorry cannot remember all models
12-06-2021 11:59 AM
Moto phones apparently do have a signal strength issue when connecting to the 4G LTE network.
Moto g7+ -99 dBm 41 asu Google Pixel 3 -92 dBm 47 asu
12-06-2021 11:42 AM
@dmbcanada wrote:Signal is excellent on the top floor of my house, but ground level sucks even outside. I have a MOTO G Fast and has all the proper updates. My family members who have different phones have same data issues.
What other phone your family members using?
But it seems this has to do with the material in your house as you said it's good on the top floor. I guess if you go out to the backyard, it works well too?
12-06-2021 11:39 AM
Yes it says disconnected, I do not always have data on.
12-06-2021 11:12 AM
Is your mobile network state disconnected?
12-06-2021 10:57 AM
So I live in London, ON and have a Telus tower and 2 Bell towers within 3 km of me. I have -108DB. I had switched to 3G due to some previous issues a month ago. Switched back to LTE but still seeing those lower stats. Signal is excellent on the top floor of my house, but ground level sucks even outside. I have a MOTO G Fast and has all the proper updates. My family members who have different phones have same data issues.
12-06-2021 10:47 AM - edited 12-06-2021 10:57 AM
@darlicious wrote:Ok maybe I explained it strangely....my signal strength hovers around -100 dBm 41 asu with 3 bars showing. As I interpreted an explanation by @sheytoon on signal strength the following was my understanding. I could have of course gotten the wrong end of the stick trying to wrap my non-techie brain around this concept.
- -120 dBm - unusable
- -110 dBm - poor
- -100 dBm - average
- -90 dBm - ideal
- -80 dBm - good
- -70 dBm - average
- -60 dBm - poor
But maybe I misunderstood the lower end of the scale. If that's true why is my signal strength in the middle of Vancouver rarely below -100 dBm? And what the....is the snow making it rise or drop (?) to -109 dBm 31 asu and 2 bars?!!
-80 dBm, -70dBm, and -60 dBm are all much better than -90 dBm. -90 dBm isn't that great. Most phones don't report readings better than -51 dBm, which is essentially near perfect, at least for what's being measured/reported. You'll probably notice that LTE tends to have different types of typical numbers compared to HSPA.
12-06-2021 09:50 AM
Well I stand corrected. I don't understand why I have such a crappy signal. The moto g7+ has a far worse signal than my Google Pixel 3. I am about a mile away from 3 telus towers that are unimpeded by geography, buildings or even trees really except for one but I can clearly see two of the towers and I'm in a wood house with no insulation.
12-06-2021 09:00 AM
Yes, closer to 0 is better, but of course we won't get there
-50 to -80 is great, 4 or 5 bars, and then get worse from there, -110 to -120 is very poor, 0 or 1 bar only
12-06-2021 08:46 AM - edited 12-06-2021 10:22 AM
- -110 dBm - poor
- -90 dBm - ideal
- -80 dBm - good
- -70 dBm - average
- -60 dBm - poor
Bad weather can affect cell signal.
Ex. Does Bad Weather Affect Cell Service? | weBoost
Edit:FYR, I have -65 dBm > 4-5 bars
12-06-2021 08:30 AM - edited 12-06-2021 08:32 AM
12-06-2021 07:05 AM
12-06-2021 05:32 AM - edited 12-06-2021 11:01 AM
-90dBm is far from ideal. I'm confused when you say the part about above -110dBm and below -70dBm being poor. -90dBm is below -70dBm The closer to zero those numbers are, the better. Either way, -70dBm is an excellent reading, far better than -90dBm.
12-06-2021 05:16 AM - edited 12-06-2021 09:57 AM
If you tell us your location we can help you interpret the cell tower maps/cell tower signals.
You can also monitor your signal strength in your phone. Go to settings>>About phone>>sim card status>>Signal strength
Anything around -90 is ideal, above -110 or below -70 is very poor...in layman's terms anyhow.
Edit:
Ok nix the above statement and see below....
12-05-2021 10:02 PM - edited 12-05-2021 10:03 PM
@dmbcanada best to open ticket with PM Support and have them to confirm if there is any issue with the towers around your area
Just curious, what band and model is your phone? Is that a Canadian model of the phone or other regional variant?
and you confirm your phone is working much better in other area?
did you also try to use 3G only in the area it has trouble with?
Was the issue just happen lately or have been for a long time?
three are also sites that might give you some ideas of the towers in your area
