yesterday
Been having a weird issue the last week or so.
My voice service continues to work just fine (as far as I can tell, haven't dropped calls, can still make outbound calls when experiencing this issue). However, for hours at a time over the last few days, I have no data service.
Rebooting phone doesn't seem to make a difference, and data works fine in other areas of the city.
After a couple of hours it seems to resolve on its own no matter how much or how little I do to try and resolve it.
A cellular signal app seems to suggest that while the issue is ongoing, I still have good connection (~ -93 to -99 dBm) and am connected to an LTE tower.
Phone is a pixel 9, and like I said, rebooting doesn't seem to do anything.
Anyone else having a similar issue or have any suggestions?
Thanks
21m ago
Try resetting the Network setting on your phone and see if that helps.
46m ago
could be the network operators are making upgrades to the cell tower / antenna in your area that only affect your data. If, as you say, it works fine in other areas, I suspect it's something isolated to your vicinity. If it doesn't improve this week, message Customer Support and they might be able to look into it for you.
