11-29-2022 04:16 PM - last edited on 11-29-2022 05:10 PM by computergeek541
11-29-2022 08:35 PM
I would hope they will start improving $25 and $35 plans , too. (or even $15) I don't need 4G speed. A bit more data would be reasonable $25 for 2GB, $35 for 5GB and maybe $15 for 1 GB would be nice
11-29-2022 07:30 PM - edited 11-29-2022 07:40 PM
Would switch to it in a heart beat, if there is a $30-35 4G plan with 3-4GB data. Maybe should have switched to the $55 less $20 for 15months promotion. The only issue is that the price will inevitably inch up and up with the threw-in data which very few would fully use. Koodo used to have a $35 for 5GB plan, now it is $40, maybe it will be $45 next year.
11-29-2022 06:37 PM
If you take the $40 plan and have any loyalty, pre-authorized payments, community and/or refer-a-friend rewards then your payment every 30 days will be less than $40 (not accounting for taxes).
11-29-2022 04:49 PM
Try using the 3G plans, they perform really well and you can switch back if you don’t like it. You will only notice a difference if you are downloading large files, normal web pages are snappy as the latency is the same as on 4G. I always download large files on WiFi at home so no issue being on 3G
11-29-2022 04:21 PM
Yes choose $55 plan and add promo code 20OFFMONTHLY. It seems to work but everyone is posting to change now and it will work.
11-29-2022 04:18 PM
No, unless you consider $55-$20 promo plan.
11-29-2022 04:18 PM - edited 11-29-2022 04:20 PM
@Haider32 Nope not officially for existing customers.
Today is the last day for the $55 plan less $20 credit. Promotion
