How to cancel services and remove credit card
Rutlandkid123
I turned off pre authorized payments, But I am looking into how to remove my credit card and cancel my services. Looking to reset this phone and sell it
dust2dust
You could also update the registered card with an empty visa gift card. Then the whole thing will fail anyway.
HALIMACS
Good news @Rutlandkid123 !!!
By turning off auto pay, you are well on your way to canceling service.
When your current cycle ends, it will not renew and it will suspend, after which it will permanently become disabled.
All you need to do is remove the SIM card and destroy it and toss it away. Then you can reset the device and sell it.
inCity
@Rutlandkid123
contact  CS_Agent  Private Messages   to removeing CC.
Quigley
@Rutlandkid123  You'll have to have a CSA from Public Mobile remove all your CC information from inside your My Account.
