Points back
genie12345
Why I didnt get the points back in July?
because I updated my plan from 250MB to 500MB?
that's not fair!!!
11 REPLIES 11
genie12345
This is their mistake, and you found a bug in their system. Any rewards or compensation for you?
genie12345
So, that's all? How about tksing this team?
@slusagm @dabr @hTideGnow @will13am
i think it is time to ask PM to check and confirm why
 Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
genie12345
didn't redeem any points in the last 6 months.
dabr
@genie12345    Just contact PM support either via the chatbot (bottom right) or private message.  They'll make the necessary adjustment.  Seems to be bit of an issue lately...happened to me twice over the last two months.
hi @genie12345
can you post us the redemption page? i suspect you redeemed 15 points for $15 and renewal made using the redeemed credit won't generate rewards.
genie12345
@slusagm @will13am @hTideGnow as you see, got points back every month except July. why?
genie12345
slusagm
Plan change won't affect that
Post us the screenshot of the transaction history and we can check.  Show us not just the line for the renewal but also entries before that
will13am
@genie12345 , points back are issued after a scheduled renewal.  Sometimes it appears the following day.
HI @genie12345
did you redeem points for this plan renewal?  if you redeemed points for bill credit and the renewal only used that money for renewal, you won't get points.  Points are added based on the amount paid by credit card or voucher
