11-27-2023 11:54 AM
I have a 4G phone but would like to take advantage of the 5G data plan on the current promo of 50GB at 5G for $40/m. I know I won't get the 5G speed, but will I still get the 50GB data at 4G speeds without any issues?
I have read some posts saying you don't need a 5G phone for a 5G plan but want to know from PM for sure.
11-27-2023 12:37 PM - edited 11-27-2023 12:38 PM
Yes, you're fine. The 4G network is capable of much higher speeds than the plans allow. Just yesterday I ran a speed test at 240+Mbps on the 4G network (with a 5G plan).
11-27-2023 12:35 PM
@FasterHarder yes, definitely. Everything should work with no issues, even if you have no 5G.
11-27-2023 12:11 PM
Your Internet speed will be a little bit slower but everything else will work as expected.
Take advantage of great plan and do not worry.
11-27-2023 11:56 AM
@FasterHarder It will work fine no worries and you will still get better speeds of a 4G plan 100mbs being in the 5G plan with phone set to 4G /LTE
11-27-2023 11:56 AM
yes, it will work. Your 4G phone can use 5G plan on the 4G network. And in fact, the speed will be close to 5G top speed if your phones allow. So, it can get close to 200Mbps
11-27-2023 11:55 AM
Yes you will. Many people do this to get more out of their phone plan.
