10-27-2024
03:07 PM
10-27-2024
04:45 PM
computergeek541
Hello,
I need to know what my 4 digit pin is. My account is still on hold and I need my payment processed so I may continue service.
10-27-2024 07:01 PM
Have you ever logged into your self serve account? If not then you will need to contact customer support to set up access to it. This is necessary if you need to update your payment card info.
You may find the following post helpful regarding alternative methods of payment for your services:
Which would also mean you will eventually need the link to contact customer support via private message if you don't like to use the chatbot bubble at the bottom right corner of your screen.
10-27-2024 04:47 PM
@Handy1 wrote:@Boberto You can set up or change PIN number here
Pin Public Mobile - My Account
adding @Boberto you can buy payment voucher from shoppers drug mart and load the funds *611 to resume services right away and no PIN needed
The account PIN isn't actually required to make a payment from within the self serve site or app either.
10-27-2024 03:10 PM - edited 10-27-2024 03:12 PM
10-27-2024 03:10 PM
you can reset the 4 digits account pin here
https://myaccount.publicmobile.ca/en/account/reset/pin
or you might need to use this link to load funds into account for renewal
https://myaccount.publicmobile.ca/en/account/payment/funds/card
