yesterday
i have new sim card from PM
i need to assign it to new phone with old PM phone number...
I dont know old phone number account number..
Just know the phone number...thanks..
yesterday
Lol....looks like it takes 20 minutes to supply all the other info other than the customer support link.
yesterday
You can contact customer support to perform a Sim swap for you but you will have to supply them with enough info to verify your account. The basic info required is:
Since you are likely missing some of this info (supply the email address even if you don't have access to it.) You will then have to supply at least 3 more vital pieces of account info to verify your account. Gather as much of the following info as possible to answer the additional questions asked by the CS_Agent:
Send a detailed message to customer support describing the issue and as much of the basic account info as possible and explain the info missing ((email and 4 digit account PIN #) and wait for the additional verifier questions. Contact customer support using the link below:
Good Luck!
yesterday - last edited yesterday
@helloguys Get support to help you sim swap the number to restore number and plan
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
