12-10-2025
01:51 PM
12-10-2025
01:58 PM
Dunkman
1, mobile data is "ON" in setting, but there is a question mark on signal icon, indicating 'NO Internet Access". and i have confirmed i have an active plan with available data 1G.
12-10-2025 07:56 PM
I just open the new public mobile on Dec 5. talk and texting work. deta never work since i active the plan.
my phone is android.
12-10-2025 02:02 PM
Hi @bingli , check your APN settings under cellular data network. What does it say there?
12-10-2025 02:00 PM
More information will be helpful.
Does talk and texting work? Which model phone are you using? did data work before.?
You could try a reboot of your phone. Network rest of phone.
