03-03-2024 09:40 AM
For the $34 for 50gb plan, is unlimited data included after the 50gb limit is reached? I don't see any language specifically in the fine print about unlimited data for this plan but want to double check before switching.
yesterday
Thank you for the clarification. I found similar here. https://productioncommunity.publicmobile.ca/t5/Get-Support/Data-Overage/m-p/1132540
I am surprised at the knowledgebase in the community here. I am quite happy!
yesterday
hi @Floatplanes
PM is a prepaid provider, so, they will not charge extra. You have to buy before you use any service
So, if you have a plan without unlimited data, once you reached the max, data will just stop working
of course if you have a plan with unlimited data (like the $35 5G Canada-only plan), data will run at 512kbps if you reached the limit
yesterday
I saw this too, but the one that says unlimited also has the superscript 1. I guess basically it boils down to, if it says unlimited, it's unlimited. If it doesn't say it, it's not. So then my only question is, do the let you go over and charge you for it or do they do a person a favor and cut it off at your cap and leave you alone?
03-03-2024 12:37 PM
@hairbag1 It's really not that confusing. Those are standard T&C's where you match the term number to the numbers noted in the plan description. This is not unique to PM.
03-03-2024 12:35 PM
It doesn't say unlimited anywhere in the plan description, and it's been clarified here. The answer is no. Once your data is used up it stops altogether. Plans that included unlimited throttled data will say that in the plan description.
03-03-2024 10:41 AM
Along with all the other un-nessessarily confusing "fine print".
03-03-2024 10:33 AM
Hello @Mhutu
I guess you're right. It's not very clear to people new to Public Mobile. Let me show you how we as regulars here determine it.
As you can see by this screen shot, I've circled the 1.
Right beside it is this. Offer Details.
Now, here's a screen shot of a plan that offers unlimited throttled speeds. Noticed the circled 2.
Under "Offer Details".... 2 states unlimited throttled speeds.
Once again, I see how it can be confusing. But this is your answer.
03-03-2024 10:13 AM
I am trying to clarify if with this plan I will be able to continue using data after 50gb limit is reqched but with a lower speed. I also have a support ticket in and they have indicated that with this plan i will be able to continue using data but in a lower speed. Not clear right now
03-03-2024 09:47 AM
All of the Public mobile US-Canada cell plans do not have unlimited throttled data after the regular plan data is used up.
03-03-2024 09:43 AM
Simple answer, no.
