02-16-2024 04:19 PM
Hi everyone,
I just got a text for a $26 4G plan with 15GB plan. Anyone else got a text too? It doesn't mention the call time, should I assume it come with unlimited Call and international text? Since it mention nothing about it.
Meowington
02-17-2024 01:48 PM
Thanks.
02-17-2024 10:35 AM
hi @nathanlouie no, you won't got changed to the new system from changing plan
So, you will still receive the "dollar" rewards monthly like before even you take a new plan
02-17-2024 07:57 AM
Thanks, does the offer grandfather the "dollar" rewards or switch to the "points" rewards?
Thanks in advance.
02-17-2024 06:33 AM
@Bunnster1 Yes and yes.
02-17-2024 01:42 AM
I got the same offer too, is this legit ? Does it come with free call and text messages ?
02-16-2024 04:59 PM
I don't think it will work even I can forward, since you need to reply the message, when u reply it will come back to me , but not public mobile.
02-16-2024 04:57 PM
HI @skpine
no it wont' work. It is a direct offer. They will check if the account ever flagged for this offer and will not honour
but they have offer like this every month or two, so, your friend could receive one next time
02-16-2024 04:53 PM
Can we forward this text offer to a current public mobile customer? My friend didn't recieve it.
02-16-2024 04:52 PM
no where you mentioned the 90 days is needed to get $34.
Using the same idea, we can keep suggesting other plans. Like
https://subscribe.publicmobile.ca/en/mb/activation/plans/75GB-5Gspeed5
only $14 more, you can get 60GB more!!! that's 5 times the data offered on the $26 plan but only 53% more!!!
02-16-2024 04:48 PM
Actually, if you are on the $25 5GB now, then jumping up $8 to the $34 x 3 90 day plan with 50GB of data then unlimited throttle is a WAY better deal than the $34 4G plan you're thinking of.
02-16-2024 04:47 PM
Howdy @hTideGnow
The plan the OP was talking about was $26. So $26+$8= $34. Also, it says it right there in writing. $40 a month or $34 x 3 90 days. I did not fail to mention anything my friend. 🙂
02-16-2024 04:47 PM
That's great, I am on $25 5GB 3G speed now. I guess I get to 4G speed and extra 10GB for $1 extra. Pretty sweet for me 😊
02-16-2024 04:42 PM - edited 02-16-2024 04:49 PM
@Chalupa_Batman wrote:Hey @Meowington
Even though a solution has already be found, this is a decent offer. However, the offer I jumped on was this one.
https://subscribe.publicmobile.ca/en/mb/activation/plans/50GB-5Gspeed13
$8 more than the offer you were given, 35GB more data with unlimited throttled speeds after that. You may wish to look at this offer as it's pretty good. Granted what would make this offer even better, add US roaming!!
there is always a better deal with more data we can suggest
the one you suggest is not $8 more, it is $14 more!!! it is only $8 more with a 90 days commitment, which you didn't mention the down side of it. So, that plan is 53% more expensive on a 30 days plan or still 31% more on 90 days commitment
02-16-2024 04:35 PM
Hey @Meowington
02-16-2024 04:21 PM
hi @Meowington
YES, Basically is the same plan with more data. You wil get the same unlimited Canadian calling and unlimited international text and all the call features
