2 dollars short for plan renewal
Deeschmizz
I did some bad math and ended up with 48/50$ Necessary to reactivate my monthly plan, I live 2 hrs away from my closest store.  Is there anyway to compensate this?? I have no credit card.
11 REPLIES 11
darlicious
@dust2dust
I went by the title. But if they really need $2 I have 3 cards with balances that total $2.38. They will have to put the work in to load the funds from all 3 cards.
dust2dust
If Deeschmizz used the proper wording then they won't get that reward on a reactivation. Reactivation means suspended. But maybe they meant their next renewal.
darlicious
@AE_Collector
If the OP ever replies to the thread or her private messages......I just offered to get them set up for Auto pay. Instant $2 reward. Problem solved. It's also a solution that keeps on giving......
dabr
@Deeschmizz    In urgent cases of needing to pay, there's always online services like recharge.com or ding.com, however, they do charge a fee.
I liked the suggestion to have a friend in town or a friend anywhere who has a credit card, purchase the extra $$ value and give you the code to add it to your account. One important piece of the puzzle is whether this is for an upcoming renewal OR a renewal that has already failed due to Insufficient Funds.
AE_Collectro
@Deeschmizz
Unfortunately, the only option is to downgrade your plan for now so you will continue to have service.
darlicious
@Deeschmizz
When is your renewal?
Edit:
@Deeschmizz
I sent you a private message with a possible solution for you.
JL9
You could use your debit card as well if it's a visa debit which most banks have these days. If not then the suggestions above are probably your only options
ShawnC13
@Deeschmizz without being able to add more funds, your option would be to pick a lower priced plan for this next coming cycle.
hairbag1
Without a valid credit card...there's not much you can do on-line. Can you get a friend in town to pick up a payment voucher, call you with the 12 digit activation PIN code, then you could dial 611 to add the $$ to your account. Get vouchers at any 7-11 type of store...Walmart even has them.
edit...
Yummy
Is your account suspended?
You can manually add $2 through self-serving account and reactivate service.
To reactivate account, do manual pay, choose "Other" as payment type and pay. Credit card has to be registered with PM. You can make only 2 attempts to pay this way. If it fails you will have to wait an hour to try again.
Did not see OP has no CC 😞
Solution would be if somebody could buy voucher for you and let you know activation code so you can load it through 611 or self-serve account.
Even you can purchase voucher if you have PayPal account.
Some details are here: https://www.publicmobile.ca/en/bc/get-help/articles/voucher-payment-options
Once payment is completed, logoff and reboot the phone. Service/plan should automatically reactivate.
If it doesn't reactivate then go to the plans or usage page and click on the lost/stolen feature. Suspend your service. Log out/in. Resume your service. Your plan should automatically reactivate.
