12-19-2022 02:42 PM
Hi PM Team,
I received a mail from you today but when I checked my account, there has NOT BEEN any add-on holiday bonus. You told me that I should bring up the matter after Dec 15th, this is what I am doing.
12-19-2022 04:00 PM
when you reply YES2 and get confirmation, try this when you log in to your account....
12-19-2022 03:00 PM
Check for text from 4911. Did you block text messages from PM?
If you did, just contact a CS_Agent to add it manually.
12-19-2022 02:45 PM
Try sending YES2 to 4911
If that doesn't work then you'll have to get a Customer Support Agent to add those holiday gifts to your account manually.
Use the Chatbot Simon to get a service ticket started first.
You'll find the link at the bottom of this page.
12-19-2022 02:43 PM
You have to text yes2 4911
12-19-2022 02:42 PM
first try to send YES2 to shorcode 4911
if you got back a reply saying they will add it, good
if not, then just open ticket with PM Support and they will add it back for you.
Please open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
