12-08-2024 09:52 PM
Hello,
I got an offer to switch my plan and decided to do so for a few months. Now the $15 plan I've had for years isn't on the website anymore.
Is there a way to get the plan back, otherwise I'll end up switching service providers as I only need text. Any recommendations for similar plans with other companies?
Thanks
12-09-2024 07:32 AM
@fynn_soop Check out the Telus link that @Chalupa_Batman suggested, here it is again
https://www.telus.com/en/mobility/prepaid/plans
For $100 a year you get 400 minutes of calls and 400 text messages however if you use the current promo code you get unlimited calls and texts plus 2GB of data a month for the first year. That's just over $8 a month.
12-08-2024 10:20 PM
@fynn_soop, as the others' have mentioned, the $15 plan is only available in Quebec so you can't go back to it. You can have a look at TELUS as it looks like they offer prepaid plans starting at $15, and TELUS owns Public Mobile so transferring over should be straight forward after contacting TELUS
12-08-2024 10:03 PM - edited 12-08-2024 10:04 PM
@fynn_soop wrote:Hello,
Thanks
Hey @fynn_soop
If you've upgraded your account from the $15 plan to another, that $15 plan is gone for good. Only folks in Quebec can get that plan. These are the cheapest plans currently. Although,
Although, I wonder if there has to be a something that is mandatory under the CRTC regulations.
Here is the one from Telus. Might want to look into it.
12-08-2024 09:58 PM
hi @fynn_soop
sorry, the $15 plan is no longer available for existing customers. it is not even available for new activation other than Quebe
Sorry about that
12-08-2024 09:55 PM
@fynn_soop No sorry the $15 plan is gone and on my available to new activations in Quebec , so if you live there you can create new account on the $15 plan with new sim and new email
