PM Customer. Change cell phone #. Help pls!
Phone78change
Existing PM Customer. Need 2 change cell phone #. Get Help feature says: At My Account. Goto Account. Change Phone Number. Select Province & city. Select new phone #. Save Changes. Help pls! Unable to find this feature.
With your help, when the cell phone # is changed. Do I need a new SIM? If so, do I order online @PM?
Thanks a bunch! Subscriber: Phone78Change.
2 REPLIES 2
Phone78change
@Phil_AdelphusThanks a bunch! Your assistance is greatly appreciated! Phone78Change.
Phil_Adelphus
@Phone78change   Log in to your account, go to Profile (on the website there's a drop down near the top with a V that opens up the menu.  When you are in your profile you will see My Phone Number with a pencil icon to the right of it.  Tap the pencil and that should give you the change option.  No you don't need a new sim card.
