08-16-2021 02:03 PM - edited 08-16-2021 02:09 PM
What does everyone think of Freedom Mobile’s Prepaid plan that has 1.5gb of data? It supposedly doesn’t use freedoms network and instead uses the nationwide network. Also has LTE data that isn’t throttled, and is pretty much only $19.
Sadly doesn’t have many rewards, but it seems pretty good for the price.
08-16-2021
02:06 PM
08-16-2021
02:53 PM
ShawnC13
for Freedom Mobile has only one rewards Refer a Friend for $25 you and your friend will getting one time bouns credit for $25 for new Activate account with 30 day,
Removed solicitation portion as it is against ToS (yes even for competitors lol)
for public mobile The Refer A Friend Reward
How Does It Work?
It’s simple: you will earn $1 every 30 days for each friend you refer to Public Mobile who enters your unique referral code in the referral code box during activation. Plus, your friend will receive a one-time credit of $10. You’ll continue to earn Rewards on plan renewal dates as long as your friends remain active customers.
08-16-2021 02:10 PM
@Asher2 I did a quick look at it, it said the data is Freedom Data, so it use Freedom network, isn't it?
08-16-2021 02:14 PM
From what I’m looking at here, it says it doesn’t use any Freedom Data. And uses the Nationwide network instead. Also says that in some of the other prepaid plans. (Some of the plans there use Freedom network though)
08-16-2021 02:15 PM
Dare I say this should be in the lounge.
08-16-2021 02:15 PM
Ah well I wasn’t sure what section this was supposed to be in so I just chose this one
08-16-2021 02:17 PM
@z10user4 wrote:Dare I say this should be in the lounge.
pretty sure.. i already ordered a drink and waiting for you guys in the Lounge.
08-16-2021 02:17 PM
It's a bit of a touchy subject around here but really...talking up a competitor doesn't seem appropriate for this part of the community.
08-16-2021 02:17 PM
i have a 2 friend the use Freedom Mobile uses the nationwide network. is good and after your data uses limit the data never stop is still working but is going slow data not fast, you know
08-16-2021 02:20 PM
That is true, my fault but wasn’t sure about it. Should I expect this post to be moved to The Lounge?
