a month ago
- last edited
a month ago
computergeek541
How do I manually port my phone number from public mobile to freedom? My SIM card was thrown out
a month ago
@Laurie15 wrote:To port your phone number from Public Mobile to Freedom Mobile, you can request a transfer through Freedom Mobile's customer care or at a Freedom Mobile store. You can also request a transfer when you create a Freedom Mobile account.
The above doesn't answer the customer's question. Performing the above steps won't work as number porting to Freedom would fail in this situation.
a month ago - last edited a month ago
Your option is to purchase a new SIM or eSIM and Change Your SIM Card in the Account tab since Freedom is not part of Telus. If it was Koodo or Telus then a manual confirmation is possible.
Also your PM account must be active to confirm and complete the porting process.
If you don’t want to purchase a SIM/eSIM then just pick a new number from Freedom.
a month ago
a month ago
@Pal-wa wrote:How do I manually port my phone number from public mobile to freedom? My SIM card was thrown out
Well that's gonna be a problem as you need your PM account to be active so they can send you a message to confirm the port request. Use this link to message Customer Support to see if they can help out...
