eSIM to SIM
01-21-2025 03:48 PM
Hi. I currently have an (older) phone that supports eSIM. I plan to buy a new mid-range phone that does not support eSIM. So I need to buy a physical SIM. Two questions:
1) what is the difference between the two physical SIM options on Amazon?
https://www.amazon.ca/Public-Mobile-Unlocked-Canadas-Subscription/dp/B0CD896ZZH
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
2) how to do I switch my service to the physical SIM on the new phone?
Thanks in advance!
Service
01-21-2025 05:42 PM
It looks like same company is selling them which is Public Mobile.
The only difference I see is that cheaper one (as per picture) does not come with SIM adapters and you get only micro SIM while $10 SIM comes with adapters to regular and mini SIM.
I would go with cheaper one as most (read: all) phones these days take only micro SIM.
01-21-2025 03:50 PM - edited 01-21-2025 03:50 PM
1. no difference, the old style is cheaper, but same sim technology
2. login My Account, and update the sim card number on the profile page, then reboot phone
