unable to log in to my account ?
Simmo69
Have requested email to reset password, but not received ??
@Cangalba wrote:
I have been trying all day to log into my account to no avail. I have click forgot my password though have not received an email either in inbox or spam. Not sure what happens from here onwards. I had logged in before without an issue and now, everytime I use the old password seems the system is locked. Help please thanks
You may need to wait one hour before retrying.  Also clear all your cache and cookies and try a different browser/incognito mode.
If nothing works you may need to send a message to Moderator_Team here:https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Response back from the moderators could take 2-48 hours.
@CangalbaYou will need to contact the moderators with this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Expect they do get back to you within 48 hours.
Cangalba
geopublic
@Simmo69  Check your junk folder just in case. Also make sure you are using the correct email. Clear your cache and use incognito mode if possible.
Dunkman
@Simmo69
If the reset password function does not work, you will need to contact moderator.
Send a private message to moderator through the following link :
Triguy
It can take 48 - 72 hours for a response from a moderator depending on workload.
Moserator can be reached at
