07-15-2017 01:01 PM - edited 01-04-2022 02:21 PM
07-15-2017 04:09 PM
07-15-2017 04:07 PM
07-15-2017 01:55 PM
@Kitkat86 wrote:
thank you for the help and I was only on a 30 day plan almost done the 30 days and yes I have internet at home but Its not the best so it buffers for like an hour so then I use my data! looking for new internet but for now I'm.stuck with it. I just transferd from wind so the 3g data is the same as winds right? thanks again
If you just transferred from Freedom, why are you on a 30 day plan? The recently ended promo is a 90 day plan that provides 12 gigs of data for $120. Perhaps you should discuss with the moderator team and have them put you on the Freedom promo. Just mention that you messed up and ended up selecting the wrong option.
As for Freedom 3G vs Public Mobile 3G, they are different. With Freedom you are subject to the vagaries of the network coverage and congestion. So, data speeds can vary. With Public Mobile, they purposely throttle 3G is a virtually unusable 2.5 mbits/s. As suggested, inquire about whether they will extend some goodwill and move you on the expired promo.
07-15-2017 01:45 PM
07-15-2017 01:41 PM
Also what is your current plan and pricepoint? there might be some options we might be able suggest.
07-15-2017 01:36 PM
so if you want data now you can
3g is upto 2.5 mbs where as lte is usually greater than 30. so it is significatly slower but still usable if you wnatch HD movies you will buffer. look at jeremys announcement re 3g to see the differences
07-15-2017 01:36 PM
@Kitkat86, first things first, I hope you do realize that new price plans have just come out recently. So, if you choose a current in market plan, you might find yourself paying a whole lot less for more money. Be careful. With the public announcement out of the way, there are two way to do a plan change, 1. make change effective immediately, 2. make change effective upon renewal. It seems like you are interested in option 1 because you ran out of data. In either case, you go into the self server portal, select what you want and select one of the two aforementioned options. Again, big warning, the in market plans SUCK.
07-15-2017 01:35 PM
@Kitkat86, so you will need to log in to your self serve account. Then hit the plan and addon tab. It will show your current plan and beside tht there will be a button that says change plan. Click on it and select the new plan that you want. After this I am not sure if it asks you if you want to future date this chaneg or to take effect immediately (I have not does this).
07-15-2017 01:28 PM
07-15-2017 01:11 PM
@Kitkat86, you can do a future dated plan change that will take effect on your next renewal. Remember the 18gb is at a throttled 3G speed
07-15-2017 01:10 PM
