01-08-2025 11:41 PM
My wife had problems with her Public Mobile add on when travelling to New York City, mostly to do with dead zones. I have an upcoming trip to Mexico and USA and was going to change my subscription to the 3 country plan. Curious how people with the 3 country plan have fared with their coverage in Mexico and the USA
01-09-2025 12:27 AM
It should work great for the most part, but as with any cellular network there will be dead zones.
Also note that Public Mobile has adopted a new unofficial policy whereby they don't give you m/any options to downgrade your plan. So if this is an increase in spend, you may be stuck with this plan going forward. I don't personally think that's a bad thing, but some might if they're on lower plans that they may want to downgrade back to when they return to Canada.
01-08-2025 11:46 PM
many had no trouble using the service in Mexico. Just make sure the phone connects to Telcel or AT&T (manually connect them if needed)
01-08-2025 11:45 PM
we're in Mexico right now and wife has the Canada/US/Mexico plans. That plan is working exactly as if we at home...no problems whatsoever. We've used it successfully earlier this winter for quick trips to eastern Washington state...no prob.
