user locked
iPhoneMax
i am wirh you for more than 5 years i cannot reset password
tey use eversafe not working..what is email address i can get help
xxxxxxxxxxxxxxxxx@xxxxxxxxxx please contact me thanks
@iPhoneMax @softech gave you the link to send a private message to a CS_Agent in your post “user locked” that you created right before this post! Where you were asked to remove your email address from your post for your own privacy & security due to this is a public/open forum for all to see!
Edit: To add info!
@iPhoneMax  Try hitting resend a couple times . Do you get  option to send to email instead
@iPhoneMax
please remove the email for your own protection
Was that you cannot get the 2FA code on your phone and unable to link My Account with your login?
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support and have them to help in this situation:
Private message CS agent at
@iPhoneMax  sorry, there is no email to send to PM support.  You have to message them via Community here
Of course, you can also share your questions, and you could get faster response here from your fellow Community members
@iPhoneMax  Here how to get support
message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
iPhoneMax
anyone know email address to get support
my account locked
