Benhe
I'm using a plan for 30 gigas and 40 bucks. But it changed to 15 gigabytes this month.What's the matter?
Your original post said $40/30GB but only getting 15GB. Now you're saying $44/30GB. It's tough to help with conflicting info and limited details.
Did you used to have the $40/15GB plan and then you switched to the $44/30GB plan? Are you sure the plan change went through? As others have said, login to your account in Incognito Mode to be sure of what you actually have.
@Benhe  why you think the plan changed to 15GB?
can you login My Account again using Incognito mode and go to Plan & add-ons page and confirm the plan details? maybe send us a screenshot?
Also, check the Payment history page and confirm how much PM charged you and what plan they renewed you on?
Add: go back couple renewals and confirm if PM ever charged you for $44-30GB
Benhe
That's right. $44 and 30g,But it suddenly changed to 15g. Without realizing it, they cheated on me.
@Benhe
give us more info.  when did you get the plan? which province you are in?
DennyCrane
I don't recall a $40/30GB plan. There was a $40/15GB plan; there is a $44/30GB plan; a while back you could get a 90 day plan for $117 ($39/month) for 90GB.
@Benhe  First double check like this
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
if it’s still not right please message support to fix
message support directly
while your already here and logged in the community you can send a private message   To CS_Agents click
