does the 1000 U.S. Long Distance Minutes has a time limit, does it only last 15 days?
Giovani7
Giovani7
Thank you everyone, Blessings!
QekaQ
What you need to know:
  1. Unused long distance add-on minutes do not expire and will roll over to the next plan period
  2. Customers with existing long distance add-ons can continue to use their minutes until the minutes are depleted
@Giovani7  It will roll over untill all used up no expiry
@Giovani7
US long distance has no expiry.  You keep them until you used them up
FYI, the 15 days expiry ONLY applies for the US roaming add-ons
