4 weeks ago
To Whom it may Concern,
I am travelling to the US for a couple of weeks and want to confirm if any additional cell phone coverage is required.
My current mobile subscription plan is "$34 ULCWUSMEX Base Plan-60GB-5G coverage".
The "Canada-US-Mexico" plan I have, says it includes "Unlimited Canada, US & Mexico minutes and messaging plus 60 GB of data"?
Confirm this means I use my publicmobile phone to call from anywhere in the 3 countries, from / to any of the 3 countries for free?
Does this mean I can turn on and use roaming for free in any of these countries?
Also can I receive / send text messages in any of these countries to any of these countries up to my 60GB limit for free?
I don't want to get caught!
Best Regards,
Rascal_007
4 weeks ago - last edited 4 weeks ago
you can def use your cell in any of the 3 countries to call / text / use data...just as you would at home...with no worry of overages or any other extra fees later on. You're able to call most any Cdn/US/Mx number while you're in any of those 3 countries. Just make sure to enable Roaming so you can use data.
