12-31-2023 09:56 PM - last edited on 01-01-2024 02:05 AM by computergeek541
10-07-2024 04:12 PM
Thank you. This is so good to know.
10-07-2024 03:49 PM
hi @daves35
yes, from what I tested, Fongo can be used internationally.
just sending text is not free
10-07-2024 03:09 PM
Thank you. Can I use Fongo internationally? I essentially just need it for SMS or receiving calls?
10-07-2024 01:22 PM
hi @daves35
there is a chance of No. TextNow has change the system and only able to be used in Canada and US
you might want to also setup a Fongo account. With Fongo, you can call and receive for free, receive text for free but you need to buy addon for sending text
10-07-2024 01:21 PM
Will I be able to use my Canadian Text Now number in Mexico for text, calls over wifi the way I do now?
10-07-2024 01:19 PM
I have a Canada Text Now number - will I be able to use it in Mexico via wifi the same way I do here?
01-01-2024 01:06 AM
I would suggest you use TextNow app or WhatsApp for free wifi calling and texting. Your other option is to purchase a local SIM or eSIM.
I use the TextNow SIM with a 30 days Roaming add-on for 1gb to 10gb of data at 5G in USA/Mexico.
12-31-2023 10:23 PM
@ottknott: As a person who travels to another continent often and every year I find that the best thing to buy if you are going to a particular country for an extended period or go to that country often is a SIM card from that country. This will make sure you are connected all throughout. And as for Mexico this article will summarize what you can buy; https://www.mexicotravelsecrets.com/mexico-sim-card/ and from the looks of it it's pretty cheap the cell plans over there.
In general there's many countries out there where cell phone plans are far cheaper than in Canada, so if you like to do a bit of research and ask some locals or friends living in that country, then you are in for a real deal. 🙂 🙂
12-31-2023 09:59 PM
Public Mobile only works in Canada and the United States (with the purchase of roaming add on). You can not use your Public Mobile in any other country. If you wish to use cellular services while you’re in another country, you can look at https://www.airalo.com/ for affordable data plans and then download an app like Fongo and pick a local number to where you currently live. They do however charge for texting. TextNow is free calling and texting. You can use both of these VOIP programs via WiFi or on a data only SIM card.
12-31-2023 09:59 PM - edited 12-31-2023 10:00 PM
@ottknott sorry, no roaming service in Mexico. You have to use local data sim or travel eSIM or just Wifi to get connected. Download free VOIP app TextNow to make calls for free with Wifi or local data
