Number port
Ss58
Hi, I switched to pm from koodo received a text from koodo to port number over, number has not been ported yet, koodo said I am registered with pm now, I would like to talk with someone and find out why my phone isn't working cannot receive texts or calls
Thanks
@Ss58
Just click on your avatar top right then Messages.
@Ss58
Your Koodo SIM will continue to work for about 2 hours until porting is completed. Once you see SOS on your phone, power off your phone and switch to the PM SIM.
If you switched your SIM too early. Check to see if the Koodo SIM is still working. If not, reboot your phone with the PM SIM in your phone.
Ss58
Thank you, where is the number I'm having trouble finding the community inbox
@Ss58  Was your Koodo account pre paid ? Or post paid if post paid I can private message you the porting team number and the can help fix . If pre paid you need agent to transfer for you
send  a  private message   To CS_Agent
HI @Ss58
can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
