07-29-2026
07:22 PM
- last edited
3 weeks ago
Dunkman
Hello, I recently lost my physical sim card and bought a new one. The public mobile phone number is still associated with the lost sim card so I can’t receive verification codes on the App. In this case, how do I replace my physical sim card? Can I use my email temporarily to receive a verification code? Thank you!
07-29-2026 07:45 PM
@Nick222 wrote:Hello, I recently lost my physical sim card and bought a new one. The public mobile phone number is still associated with the lost sim card so I can’t receive verification codes on the App. In this case, how do I replace my physical sim card? Can I use my email temporarily to receive a verification code? Thank you!
Hello @Nick222
Of course, when it tries to send the code to your phone, click on "Didn't Get The Code" and there may be options there to send to email if the account was set up correctly. If you are able to get in that way, then once you are in, use this link to go directly to change the SIM card number.
https://myaccount.publicmobile.ca/en/account/profile/change-sim-number
If you do require further assistance because you're unable to get into your account, you're more than welcome to reach out to customer service to help reset your account to change the SIM card.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
07-29-2026 07:34 PM
hi @Nick222
If you have trouble getting 2FA code via text, click Didn't receive code or Resend code and then choose Send email or Send voice message to get the 2FA code via email or voicemail (you can call yourself from another phone to retrieve the 2FA voice message)
After you logged in the app, go to Profile to update sim card (or if you are using My Account using a browser, go to Profile page)
But if you cannot get the code via email or voicemail, you need to ask PM agent to help. You can submit by direct message:
