transferring a mobile phone number from a company
yara_fel
transferring a mobile phone number from a company bell
@yara_fel
@yara_fel wrote:
I recieve massege
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at: https://publicmobile.ca.ada.support/chat
You can patiently wait for PM to contact you.
We generally recommend avoid using ESN/MEID. Just use your Bell account number.
Since it is a porting issues, there is a phone number to call for the Telus porting team.  That likely would be faster.  I will private message you.  Check your inbox (envelope on upper corner of website)
pmbc
@yara_fel Do you still have your Bell sim in a phone?  Otherwise they can't reach you.  You can also reach out via the link they provided.  You'll need to provide them with a IMEI or Bell account number so have that info handy.
yara_fel
I recieve massege
Dunkman
@yara_fel
Any specific question?
Here is help article of transferring phone number:
https://www.publicmobile.ca/en/on/get-help/articles/choose-your-phone-number
@yara_fel
Do you have a question or is this a comment?
