10-27-2019 02:33 PM - edited 01-05-2022 07:45 AM
I've been using public mobile for years, and it was always fine, but recently my texts stopped sending. Incoming texts and all calls still work. My plan is fully paid, and I have unlmited texts on my plan. I also already tried restarting my phone, and even reported it lost/stolen, turned off my phone, then turned it back on, and then reported it found.... nothing helped!
Any suggestions?
10-27-2019 03:24 PM
You may want to try your PM sim card in another phone. To help determine whether it is a hardware issue versus PM service problem.
Depending on your phone, you may want to check the text APP. Clear cache or reset text app.
Other things to try:
Toggle airplane mode on, wait a few minutes and then off.
Network reset.
10-27-2019 02:48 PM
There have been a few other concerns like this in the past. Some of them contacted @CS_Agent and had their SMSC settings pushed by a moderator, others followed something similar to the solution in this post:
Depending on what you are comfortable, you may want to try one of these, @Renee2215 .
10-27-2019 02:34 PM
Try sending a message to yourself. I had this issue once with Telus, and the tech support gave me this advice and it worked for me.
What kind of device?
