texting
CWbear
Been 5 days since I activated my account, still cannot send or receive a text unless i am connected to wifi.
10 REPLIES 10
eddieO
@CWbear, try to remove the phone number from iMessage's settings and reboot the phone.  Add the number back to the settings and test again
AK32
are you able to make/receive calls or only having issues with text?
If only issues with text, check the settings in your phone to enable sms texting.
If issues with both, it is a subscription/service issue.
Meow
Most likely you are using apple and its proprietary apps.
Try to use NORMAL sms feature of your phone and not apple's.
CWbear
subscription has been active since the 9th
CWbear
IPhone 13 mini; features work as long as I am on WiFi
AK32
that sounds about right, so you are using imessage/wifi currently. I am going to assume your texts wont work with anyone not using iOS/imessage. If you are unable to send or receive texts, and cant make or receive phone calls, it sounds like the account did not get fully activated yet and you will need to log in to your account settings to take a look.
CWbear
I am on a IOS device, I expect given I can send and receive text messages on WiFi, that is the case. Dont have my phone to check that.
Phil_Adelphus
@CWbear   Contact customer service by submitting a ticket at the chat icon bottom right of this page.  If it doesn't work an alternative is to send a private message to support using  this link
An agent will reply at the envelope icon top right of this page or tap your avatar for messages if no envelope.
AK32
If only texts work while on wifi i assume you are on an iOS device and the wifi is using imessage which doesnt require data, can you confirm if this is the case?
If so, it sounds like the account did not get activated, can you see if your subscription is active currently?
eddieO
@CWbear, are your other features working like calling in/out, data? What phone are you using? These answers may help us provide solutions
