04-02-2025
11:55 PM
04-06-2025
11:59 PM
Dunkman
Hello I just recently posted over from Rogers and using a d iPhone 15 I am unable to receive any text messages but data and calls are working fine. I am. It sure what t/s steps I can do I have reset the network connections and still has no luck.
04-05-2025 05:55 PM
Thanks I found out after my text were not even working PM refreshed my number and my issue has been resolved.
04-03-2025 12:00 AM
You need to re-register iMessage
On iPhone settings, remote the phone number and reboot phone. Then go back and add the phone number back, iMessage will then re-register
04-02-2025 11:59 PM
@Sal888 Do you have iMessage turned on? Try disabling that and test SMS incoming and outgoing.
https://selfsolve.apple.com/deregister-imessage/
