esim
kevinlaurie
error no esim installed
7 REPLIES 7
kevinlaurie
no e sim installed in setting
Did you use the PM app to activate ? yes
Dunkman
@kevinlaurie
You likely will need to contact customer service agent
Send a private message to CSA through the following link :
Expect 1-3 hours response time.  Try to include as much information in your private message to CSA.
Did you use the PM app to activate ? If you did z you dont need the QR code, the app will install the esim for you
Check sim manager on your phone or check Settings, Cellular screen, there should be a Public Mobile esim there.  Make sure it is enabled or enabled with Turn on this line option. Then click Reset Network Settings
kevinlaurie
Are you a new customer? yes
 Activating new account with eSIM?  yes
Did you port your number over?  i am trying
The more details the better. If new customer, did you receive an email with a QR code for eSIM. ....no
@kevinlaurie
Did you activate with the PM app?  If use the website first, did you switch over to the app to finish activation?  Were you charged?
kevinlaurie
new customer, i did not received a email with a qr code
Dunkman
@kevinlaurie
More details would be helpful.  Community members are customers like yourself. We have no access to individual accounts.
Are you a new customer?  Activating new account with eSIM?  Did you port your number over?  The more details the better. If new customer, did you receive an email with a QR code for eSIM.
