06-08-2024
12:08 PM
06-08-2024
11:00 PM
computergeek541
Hello I was wondering if there is any way that I can switch phone numbers between 2 pubic mobile accounts.
reason
I would like to have all the accumulated bonuses I have on a back up public mobile line to be used by the other line thats used all the time.
06-08-2024 12:55 PM - edited 06-08-2024 12:57 PM
Yes you can if you use the SIMore SIM adapter to hold up to 3 SIMs on one phone and go through the SIMore app.
They are available for iPhone and Androids. Check out the video on the bottom of link.
There is also a wireless eClip version.
https://www.simore.com/en/triple-dual-sim-4g-iphone-8-apple-case-adapter-wx-triple-8.html
06-08-2024 12:46 PM
It may be possible to transfer the one number by porting the one number over but you will be closing that account and losing the other number. But not sure you can port from PM to pm.
06-08-2024 12:13 PM
Nope, cannot be done!
Simple solution would be to switch SIM cards and use one phone to collect max points.
06-08-2024 12:09 PM - edited 06-08-2024 12:10 PM
Hey @fredweet122
Sadly, this can not happen. Any credits such as the More The Merrier credits from years past are locked and tied to that account number. Not tied to the phone number.
