09-21-2023 11:03 AM
my phone calls continue to drop even when I'm sitting still in my house and many times I get a "sos" instead of bars on my phone.
09-21-2023 11:26 AM
a moment ago
my phone is in 3G mode my phone calls continue to drop even when I'm sitting still in my house and many times I get a "sos" instead of bars on my phone this happens when I'm at my house inside or outside..... i am about 30 min from toronto international airport in the countryside
09-21-2023 11:11 AM
HI @ingridoo
Do you have the issue mainly when you are at home? What phone do you have?
Try to take sim out , wipe it clean and put it back. Then Reset All networks and check if it works better
Also, change the network mode, try 3G Only and see if it helps
And test your sim in another phone as well
09-21-2023 11:08 AM
@ingridoo Might want to ask support to refresh your account
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-21-2023 11:04 AM - edited 09-21-2023 11:08 AM
If you go into your cellular settings, can you try connecting to the 3G network for voice and data and then rebooting? It could be that 4G/5G coverage in your area is less reliable.
Also might be worth checking if there any outages currently in your area:
https://www.telus.com/en/bc/outages
If you have another device it also might be worth trying your SIM in it to see if it’s a device specific issue or not.
