sim and esim
Aiden_Q
I already had an esim card activated on my iphone, can i purchase a new physical sim card with same phone number to be used on my ipad or some devices? I just wanna  to use the data function of the sim card to access the Internet on my ipad.
You can not share an account across multiple sims (esim or card).
If you have access to a device with a card then try putting it in the ipad and see if it works for data. If it does then you could start up a new account using a card and use it in the ipad.
@Aiden_Q
each sim is registered to a separate account...you can't share accounts between 2 sims.
Aiden_Q
This method is feasible, but I want to use them seperately.
dust2dust
No. Just use hotspot off the phone.
