12-16-2022 11:09 AM - last edited on 12-16-2022 04:00 PM by computergeek541
12-16-2022 01:32 PM
@glencgdcincca wrote:PM account is active and sim is in the phone
Just so we're all absolutely clear...you do mean of course that the PM sim is in a phone, right? The text goes to the PM sim.
12-16-2022 11:50 AM
@glencgdcincca open a ticket using this direct link with PM for them to confirm if they receive the porting request
https://urlshortner.tiia.ai/Lc9xk8
If you have made a request to port your number to another carrier and have not received an SMS from Public Mobile to confirm your request, please open our chatbot via this link. This will put you in touch with our Customer Support Agents who will be able to assist you.
12-16-2022 11:49 AM
I retriggered the process after 90 min already once
all the info is correct
i can receive texts
12-16-2022 11:46 AM
@glencgdcincca Please check with your new provider first to see if anything missing. Ask them to re-trigger the process
Also, make sure your PM service is working, like you can receive regular text from friends
12-16-2022 11:45 AM
two plus hrs
12-16-2022 11:41 AM
@glencgdcincca how long you have requested porting?
12-16-2022 11:39 AM
still have not received any text to port
Thanks
12-16-2022 11:32 AM - edited 12-16-2022 11:33 AM
@glencgdcincca
Click on the arrow in the top right of your original post and click on Edit
12-16-2022 11:32 AM
Click on reverse V in circle to edit and remove personal information or you will get spammed.
It will take up to 90 minutes to get the text with the PM SIM in your phone…account must be active to have your old number ported over.
12-16-2022 11:29 AM
Thank you so much!
12-16-2022 11:29 AM
@Spuggetabouti1 wrote:Hello @glencgdcincca !
- Obtain Public Mobile SIM card
Read OP post carefully!
He is porting OUT of PM, not to PM...
12-16-2022 11:27 AM
Please remove numbers from public forum.
YOU have to initiate porting out at other provider.
When you do that, Leave your PM SIM in a phone and reply Yes within 90 minutes after receiving SMS fromPM.
Do NOT suspend or close PM account. It will be closed automatically after porting is competed.
12-16-2022 11:27 AM
how do I remove the post ?
the request for porting from my new provider has been completed
the sim is in the phone and I am not receiving the text to authorize the port
what do I do now?
12-16-2022 11:22 AM
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
12-16-2022 11:16 AM
@glencgdcincca this is an open forum and please remove your account number and phone number for your protection.
For porting, first make sure your account is still Active
Then request the porting from the NEW provider.
Once requested, make sure your PM sim is still on a phone ready to receive text. PM will send you a text for your authorization to port. You need to reply YES within 90 mins
Once replied YES, the porting will be completed within 30 mins to 2 hours
12-16-2022 11:12 AM
You need to initiate the port with your new provider. Make sure your PM account is Active and that you keep your PM sim in your phone to receive the confirmation text to port out.
