12-16-2022 11:38 AM
12-16-2022 02:29 PM
Thanks for all the details. SIMon was not very helpful, but what can you expect?:) I will keep an eye on the reply. Have a good weekend!
12-16-2022 02:27 PM
Thanks a lot for all the details. Ticket submitted through account.
12-16-2022 02:25 PM
thanks ticket submitted as suggested. Have a good weekend!
12-16-2022 02:24 PM
Thanks yes I found the text from last year, did not work though:)
12-16-2022 02:23 PM
Thanks, tried that, only got - not eligible for the offer. I believe I should receive the sms first like last year.
12-16-2022 11:44 AM
Try sending YES2 to 4911
If still no gifts, then use the Chatbot Simon to get a service ticket started, and you can get the gifts added manually to your account.
12-16-2022 11:43 AM
Note that the text should be sent to 4911, not 491
12-16-2022 11:42 AM
No problem. Contact agent to add those rewards manually to your account.
12-16-2022 11:40 AM
first try to send YES2 to shorcode 4911
if you got back a reply saying they will add it, good
if not, then just open ticket with PM Support and they will add it back for you.
Please open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-16-2022 11:39 AM
Try texting YES2 to 491.
If still no promos:
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
